禅意单人沙发(壹柒版)
更扎实的用料,更大的靠背斜度,更放松的坐姿设计。壹柒版禅意沙发系列采用偏自然材质的面料制成,布料更加厚实,每平米重达530g。实木骨架结合软包材质,外刚内柔,保留了中式的禅意,同时采用了西式沙发的坐面,既有舒适度又不失气场。有米兰、灰紫、灰绿三种颜色可供选择,建议搭配本系列多人沙发。
Zen Style Sofa (17 Edition)
Better quality material, bigger incline angle, more reflexing seated position design. 17 Edition Zen Style Sofa series is made of more natural fabric. The cloth is thicker, 530g per square meter. The solid wood fame is combined with soft material, solid outside but soft inside. It preserves Chinese Zen Style and meanwhile adopts the seat of western sofa, comfortable and high quality. Have three colors, Milan, grey purple and grey green. Suggested to match with multi sofa of the same series.
马扎(壹柒版)
植鞣革马扎结构重生,在原版设计的基础上进一步升级改良。坐面为天然环保纯手工制作的植鞣革,比之前版本更加厚实,皮面颜色为梵几特别定制色,色泽温润。底部使用双层结构,以增加皮面的受力度,整体更为结实耐用。架构设计了一个突出的拎手,可随身提携,无论是在院内,还是外出使用置于车里,去户外钓鱼、热血奔腾的音乐节现场或是各式等位站票人流中都可以随手摊开助力,必要时,马扎也可以作为家中餐桌边的备用座椅。
Campstool (17 Edition)
The structure of Vegetable Tanned Leather Campstool is reborn. It has been upgraded on the base of previous edition. Seat is made of natural hand-made vegetable tanned leather, and it is thicker than before. The leather color is specifically designed for FNJI, mellow and full. The bottom part has two layers in order to increase its load-bearing capacity and makes the whole structure more endurable. There is a protruding handle, so the stool is portable and can be used in the yard or in the car, or when go fishing or attending the heart burning Music Festival, or waiting somewhere or having no seat when traveling, the campstool can be handily used. If necessary, the campstool can be used as backup chair besides Chinese Dining Table.
平云衣架
梵几的全新力作,黄铜、皮料、原木三种材料的完美融合,结构上延续了马扎的折叠结构,利于空间收纳。高低双杠的设计适合钩挂,也同样适合搭挂衣物。尺寸的确定经过了长时间的测用考量,对不同大小的空间包容性强。同时为避免产品使用过程中意外倾倒,设计师特别将金属转轴尺寸设计调整为,下部尺寸大于上部尺寸。漆面可以有效防潮防水,避免变形。
Flat Cloud Clothes Rack
FNJI new masterpiece. It perfectly combines the material of brass, leather and log and continues the structure of campstool which is good for storage. High and low racks are designed for hooks as well as hangers. The decision on size is made after long testing and usage and the space is more inclusive. In order to avoid the rack will fall down accidently, designer changes the size of the metal shaft that the bottom part is larger than the top. The paint is effectively waterproof to avoid deformation.
抽屉写字桌
一款让办公环境变得更简约更易收纳的设计——单屉写字桌,由大小两抽屉和利落线条组成。大抽屉可以放置15寸笔记本电脑和一些日常用品,小抽屉可以用来放接线板。特别之处在,梵几的设计师从日常办公桌收纳的需求中,设计了侧面凹槽,数据线可沿着凹槽顺至桌面,使得桌面更为干净整洁,同时保留了桌面的完整性。
Desk with drawerThe desk with drawer is composed of big and small drawers and simple lines, which makes the working environment simpler and easier to store. Big drawer can be used for 15 inch laptop and other daily items. Small one can store power bar. The highlight is that knowing the need of daily storage, the groove is designed on the side. The data wires can run along the groove to the desk top, which makes the desk tidier and meanwhile keep the wholeness of the desk.
Poker Screen
Poker Screen简洁明快的形态中不乏创意感,一屏即是一景。不同尺寸设计令它拥有更为自由化的陈列形式,可以自由组合、叠加摆放或单独使用。沉稳自然的木质基座,与柔和雅致的布艺软包,趣味十足,营造出风雅和悦的想象空间。
Poker Screen
The shape of the Poker screen is full of creativity, which can make a unique decoration in the room. Different sizes of the screen bring wider freedom of display methods: both be used alone and superimposed, and freely combined. The stable wooden base design with soft fabric and natural texture give viewers a sense of elegant and interesting.
The Cube Armchair
高低变化的几何体,鲜明独立且极富秩序感,The Cube Armchair通过巧妙的尺度拿捏,营造出几何形态的非对称结构造型。椅身在视觉上所形成的微妙平衡,富有动感与趣味。扶手部分,兼具功能性与设计感,实现了日常使用中“坐”、“倚”、“置物”等多元化的场景应用需求。
The Cube Armchair
The Cube Armchair has an asymmetric structure with geometric shape, which is designed skillfully. The visually balance of the armchair scale conveys the dynamic and interests of design. The unique geometries of the armrests have both functional and creative feeling which make the armchair filled with the sense of order. Besides, the Cube Armchair can apply to various environments and offer people many possibilities to use, such as sitting, leaning and putting object on it.
佚名
2017-3-01 14:22:45
